If I use USB cable to use WiFi thru my phone to laptop will it still cost me lot
  • Updated 1 year ago
Photo of Dass Pranesh
Dass Pranesh
  • 172 Points 100 badge 2x thumb
Posted 1 year ago
Photo of David
David, Mobile Master
  • 89,270 Points 50k badge 2x thumb
Do you mean using cellular data to connect your laptop to the internet? It is suggested for limited situations only. Your laptop does not realize it is connected to expensive cellular data, and can download many items in the background. In addition, webpages, etc., sent a phone are a smaller package than those sent to a laptop.  You can expect to use data at twice to three times the rate you do on your phone. Higher if it downloads any updates while connected.
If you do use your phone this way, be cognizant of the data differences.
Photo of Allan
Allan, Mobile Master
  • 56,956 Points 50k badge 2x thumb
If you choose to do this I would suggest setting a metered connection on your computer so that it uses less data. As well I would suggest a browser like chrome so that it doesn't download as many images, automatically run flash programs, etc.
