If I Turn on my phone outside of canada, I gone get charges?
  • Updated 1 year ago
Photo of Fernando Ramirez
Fernando Ramirez
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 91,316 Points 50k badge 2x thumb
Not automatically. If you keep it in airplane mode and turn on Wi-Fi it will keepyou from getting charged. You can also take the Sim card out to keep it simple.
Photo of Allan
Allan, Mobile Master
  • 57,096 Points 50k badge 2x thumb
When you cross into another country you will receive a text saying what you can get charged for and the prices it will be. For example on most plans incoming texts while in the US are free. Just check your plan out and adjust accordingly. If you have free incoming texts than just turn off your data, if not than turn it on airplane mode, etc.
Fernando Ramirez
Thanks, for your help, because, am outside of canada ,and I waiting very an important call, jut one so it's for that my question
Photo of David
David, Mobile Master
  • 89,450 Points 50k badge 2x thumb
If you are not in the USA, you require the free International voice add-on be active on your account to connect to other carriers.
You can  add the free “International Voice Roaming" and / or the free “International Data Roaming” add on. Then turn airplane mode on and off. When your phone connects it should be working. Buying any of the Travel Add-ons only nets you a savings on your roaming fees, it does not change anything about the ability of the phone to roam. Without the Voice / Text / Data Add-on, you can still roam at pay-per-use prices. https://community.koodomobile.com/koodo/topics/roaming-texting?topic-reply-list%5Bsettings%5D%5Bfilter_by%5D=all&topic-reply-list%5Bsettings%5D%5Breply_id%5D=18384349#reply_18384349
