if i change my plan today when will it be effective? i have no data right now ...would i have some tomorow?
  • Updated 2 weeks ago
Photo of Christel Savoie
Christel Savoie
Posted 2 weeks ago
Photo of Mats
Mats
  • 18,028 Points 10k badge 2x thumb
Yes you should. It should happen right away.
Photo of Dennis
Dennis, Mobile Master
  • 192,366 Points 100k badge 2x thumb
When you used all your data, you will get a text that says your data has been stopped and you have options to buy more data.  Unless you are planning on getting a higher data plan for all future months, it is not worth changing your plan in this way.
Note that when you change your plan, your old and new plan will be prorated.  Ex. if you have 100 mins and you used 100min and you changed your plan to 500min, are you are only half way through your plan, you technically will only get credit for 50min for the first half and get 50 min in overages.  For the second half of your billing cycle you would be alloted only 250mins
