When does my phone activate?
  • 2
  • Updated 6 years ago
I activated my phone and it says its done but I can't send text messages yet. How long does it usually take to start working after you have activated it?
Photo of Kat Parrott-Mautner
Kat Parrott-Mautner
Posted 6 years ago
  • 2
Photo of Aaron MacIntyre
Aaron MacIntyre
  • 10,050 Points 10k badge 2x thumb
Well, last time I got a new sim & phone activated at a store, it took actually about 45mins before I was able to call and text.
Just make sure you have the sim in there right (and not backwards like I've done before), pull the battery and reboot the phone. Sometimes they need a little jump start to connect.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,250 Points 100k badge 2x thumb
If Aarons suggestion doesn't work keep in mind that it can take up to 24 hrs for your phone to become active but usually anywhere from 1 - 6 hours is the most common. Chances are the battery/SIM pull Aaron suggested will work though
Aaron MacIntyre
I was going to say 24hrs, but it sounded excessive and I couldn't find the info on the koodo site, so I turtled and went on personal experience lol
Hey man that's always the best way to go anyways. Keep up the great work man & me and you could be the next mobile masters in April ;-)
