I want to use my bluetooth headphones to listen to FM radio on my Android phone but it doesn't work.
  • 2
  • Updated 4 months ago
Hello,
do any of you know how to make my bluetooth headphones work to listen to FM radio. Right now, only the connected headphones emits sound but not the bluetooth ones. I tried on the S2, Ace and GN2 and all 3 of them have the same issue.
Photo of Don
Don
  • 6,586 Points 5k badge 2x thumb
  • 2
Goto settings, wireless and networks, bluetooth
Long press the device
Ensure media is connected and / or A2DP enabled.
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
You will need to buy a stereo bluetooth device to play music.
Photo of Don
Don
xD
@MAT
1. READ THE ORIGINAL POST! He has a Bluetooth device.
2. I can listen to music through my Plantronics Voyager + (a Mono A2DP device). Any device that uses A2DP can play music and connect to media.
3. You can play music with any of the devices without headphones through the speaker unless something is plugged into the headphone jack.
Photo of Ellae Wilson
Ellae Wilson
  • 60 Points
I'm not quite sure what I might be misunderstanding... but I own P47 wireless headphones. They can be used with a computer, with a phone or to listen to wireless FM radio. Gotta say that the idea one needs a wire plugged in to receive FM radio is way off. Unless I've missed something (and I do have an electronics degree) you guys are simply wrong.
Photo of Goran
Goran, Mobile Master
  • 88,672 Points 50k badge 2x thumb
Because they specifically have an FM radio and antenna built into them while phones only have FM receivers and no antennas. Maybe some OEMs put a whole radio in their phones. Who knows. The general rule remains a headphone is needed to act as an antenna.
Photo of Steven
Steven
  • 1,420 Points 1k badge 2x thumb
You cannot listen to FM radio with bluebooth because when you plug in a wired headset, the phone uses it as a FM antenna. You have to have a wired headset in order to listen to FM radio. A way around it is by uses the app TuneIn Radio. It uses your data (or WiFi) to get live streaming over the internet.
Photo of Don
Don
I am searching the XDA forums and it seems nobody listens to fm radio anymore because nobody has asked that question before lol
Photo of Ivan
Ivan, Mobile Master
  • 95,438 Points 50k badge 2x thumb
Steven is right, the wired headset is required because it acts as an antenna. No custom ROM will get around this as it's a hardware requirement.
I just attempted to use my Bluetooth on my HTC One's FM Radio app while the headset was plugged in and it will not play back as the sound defaults to the phone jack.
What a custom ROM may do is allow you to select where your sound output goes when a headset is connected, but there's no way around needing an antenna.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
I remember someone asking this a few weeks ago, I think. It was determined that the situation is exactly what Steven has mentioned. If I could remember where I saw that info to back it up, I'd post it lol
Photo of Rajendra Patil
Rajendra Patil
  • 60 Points
I listen fm radio on bluetooth in micromax a52
It works perfectly with Sony Xperia series. Just plug a phone jack (no need to have a cable, just the jack) and then connect to bluetooth headset and BT headphones will work to listen FM Radio. This doesn't seems to work with Samsung device. Maybe is something related with the @Throw@ option that Sony devices have.
Photo of Karandeep Singh
Karandeep Singh
  • 60 Points
i have the tune in radio app, but can not listen to it through my Bluetooth headset. please help. i am using Sony Ericsson Xperia ST18A.
You must make sure your phone and bluetooth headset support A2DP audio. If either doesn't, you won't be able to use a BlueTooth headset.
I just checked, your Sony does support A2DP. Goto settings, bluetooth, and long press your headset. Make sure media is connected. What headset do you have?
Photo of virginie
virginie
  • 60 Points
@Chad BurrI would like to buy a BT. I own an htc one s, specs says that it supports a2dp.
Do you think fm radio will work? If yes, will I need a fake plug into the jack? Thanks
Photo of Ivan
Ivan, Mobile Master
  • 96,292 Points 50k badge 2x thumb
The radio will not work over BT. When you use a wired headset, the cable acts as an antenna to pick up the radio signal. If you do plug in another cable, it may work - but you then have to make sure than the audio can be transmitted simultaneously via BT when something is plugged into the jack.
And since you have to have something plugged in, it might as well be a headset without additional hassle.
Photo of Suchit Pokhriyal
Suchit Pokhriyal
  • 60 Points
I want to use my blue-tooth to hear fm.Please help, I am using samsung galaxy ace 5830i
Photo of Ivan
Ivan, Mobile Master
  • 96,280 Points 50k badge 2x thumb
You cannot. The phone does not have an antenna for FM radio unless you plug in wired headphones (or an auxiliary cable). The cable functions as an antenna.
Photo of eingrobin
eingrobin
Just use a wired headset-easy
Photo of B2theden
B2theden
  • 2,626 Points 2k badge 2x thumb
If you have a FM enabled phone You will require headphones to listen to FM radio offline, But if you don't mind using Wifi or data you can use tunein radio tunein radio will work with your bluetooth headphone but will require internet connection. Here is a link to the app on google play https://play.google.com/store/apps/de.... But the only way you can listen to radio offline is by using your headphones.
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
I like my Sony SBH50 for this very reason!
It's natively FM-enabled, in fact, when using FM, it doesn't even need to be paired to a phone, it can do FM radio on its own.
It also sounds awesome with the right earphones :)
Definitely, Sony devices work perfectly using a simple phone jack connected (no need of the entire cable) and BT headphones to listen FM Radio comfortably. This seems to be not possible with Samsung devices and others.
