I prepaid for Global data but I don't know how to activate on my Samsung phone. Can anyone help?
Photo of don
don
  • 80 Points 75 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
That's going to be rather expensive, but sure. What phone do you have? And did you enable the international pay-per-use and international roaming add-ons in Self Serve?
Photo of don
don
My question wasn't quite right. I have a data booster pre-paid package and I want to use it to access the internet when I am not around wi-fi. I have a samsung s3 phone, I don't know how to get it to work because right now I can't access the internet if I am not around wi-fi.
Photo of Sophia
Sophia, Mobile Master
Hi Don, it sounds like you need to set the APN settings correctly:
http://help.koodomobile.com/plans-add...
Click the link "Android" and folllow the instructions :)
Photo of Jonathan I
Ah, okay. I gotcha. Sophia has the right solution.
After that, make sure data is turned on.
