I need a plan for Africa
Im going to africa for a month. I dont see any plans here that I could get?
Photo of Jill M. B Jeffery
Jill M. B Jeffery
Photo of Ahmad
Ahmad
There are no roaming plans for Africa. You would be paying $2.50/min, $10/MB and $0.60 per text sent and $0.60 per text received. I'd leave your phone at home.
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
You could always unlock your Koodo phone, it's just $35, then set up a prepaid service with an African carrier.
You can also put your phone on a seasonal hold of $15 a month. However, if you're on a grandfathered plan it will not be recoverable when you get back so you'll have to pick an in-market plan.
Jill M. B Jeffery
If u put ur phone on a seasonal hold could you still use the wifi if I are In a area that provides it?
Photo of Daniel Kim
Daniel Kim, Mobile Master
Definitely! wifi still works, it's just all cell service (text,talk, data) will be disabled when your phone is put on seasonal hold. But keep in mind if you have a really nice grandfathered plan, seasonal hold is not recommended. Hope that helps! :)
Jill M. B Jeffery
What do u mean by grandfather plan.?
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
A grandfathered plan is where Koodo honours it's subscribers who have rate plans that are no longer available. For example, Koodo honours customers that are still on rate plans that include per-second billing.
If you happen to have such a plan, applying a Seasonal Hold would mean that you would lose that rate plan entirely because per-second billing is no longer offered. You would then have to select from Koodo's current monthly plan offerings.
Jill M. B Jeffery
oh ok. well thanks everyone for the information!!! I did go with a seasonal hold today.. Leave in 2 days!!!
Photo of rikkster
Unlocking the phone would prove pointless. In North America Koodo phones are compatible with HSPA 850/1900 MHz frequencies. While traveling internationally Koodo phones are compatible with HSPA 850/900/1800/1900 MHz frequencies. The most common frequencies in Africa are 2G 900/1800 and 3G 2100 MHz. The alternative, purchase a prepaid device in Africa.
Photo of Jonathan I
Jonathan I, Mobile Master
I don't think that's necessarily the case. If someone buys an S III from Koodo, for example, the model has quad band GSM and quad band HSPA. Why wouldn't that work in Africa?
