i hv iphone 5 and all incoming calls go straight to voicemail
  • Updated 1 year ago
i hv iphone 5 and all incoming calls go straight to voicemail, pls advice what i should do. It happens for a couple days already.
Photo of js
js
Photo of Rocky Balboa
Rocky Balboa
Turn the phone in airplane mode in the settings. Turn the airplane back off after 20 seconds. If this doesn't work call Koodo 866-995-6636 option 6. Also make sure your 3g is enabled.
Photo of Carol Cannon
Carol Cannon
  • 60 Points
Where do I look to make sure3g is enabled
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,546 Points 100k badge 2x thumb
It would be under settings->cellular.
You should also check to make sure your phone is not in do not disturb mode, which would be indicated by a crescent moon symbol at the top right corner of the phone.
