Samsung s3 keeps saying Koodo is not available!!
  • (Edited)
Photo of Rabab Elfouly
Rabab Elfouly
  • 144 Points 100 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
How long have you had this problem? it could be because of a number of things. try resetting your network settings or a battery pull out. MAKE SURE you have 3g enabled.
Rabab Elfouly
for about 3 weeks ...i tried all of what u said it didnt work..except for the 3g:) how can i enable the 3 g?
Rabab Elfouly
and sometimes it says not regiseterd on a network
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
Hi Rabab!
I was about to suggest rebooting your phone, but you already did all that (battery pull and everything).
Do you have access to another Koodo (or unlocked) phone in which you can try your SIM card? If you do, please try your SIM in a different phone to rule out a faulty SIM. If you do not, your nearest Koodo kiosk will be able to make this test for you.
In an even rarer case, your phone's SIM slot connector may be faulty, but it's really not common.
Please test your SIM in another phone and report back. We'll go from there :)
Cheers!
Rabab, I just noted your problem seems to come and go... Do you live in a well covered area? Is it better if, for example, you go outside? Waiting to hear from you!
Rabab Elfouly
yes i'm living in a covered place ..but it used to work very good , and this msg appears every where not only at home ...it started like 3 weeks ago for few hours through the day,,,,but for the last weeek its completely dead !!:)
Ok Rabab, in this case, refer back to my post. Do you know anyone with a Koodo phone (or an unlocked one, like a Nexus for example) in which to test your SIM card?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
settings->more settings
make sure flight mode/airplane mode does not have a green checkmark beside it
settings->more settings->mobile network
make sure network mode is set to GSM/HSPA/LTE auto mode
tap on network operators
search networks
select koodo.
Rabab Elfouly
yup i've tried all of this:) i guess there is something wrong with my sim card . i think i have to visit any koodo kiosk to check it out
Photo of Rocky Balboa
Rocky Balboa
Eighther the sim card or the phone. Hopefully, it's the sim card....
Photo of Bill Melater
Bill Melater
  • 2,954 Points 2k badge 2x thumb
I had the same problem with my Mobile Internet stick from Bell. It was a bad SIM card.
Get a new SIM card. :)
