I have nokia E63 without sim card and I want to activate it .How I can do it ? And what is price for it ?
Photo of Sergey Stepanidin
Sergey Stepanidin
Photo of MaX Damage
MaX Damage
  • 890 Points 500 badge 2x thumb
Is your phone a KOODO device? When you say that you "without sim card" do you mean you do not currently have a KOODO sim card or that your phone does not take sim cards at all?
If your phone a non-KOODO device AND does not take SIM cards, your phone is not compatible unfortunately.
As long as you have the American Version of this phone and its unlocked, it should work with koodo.
Koodo offers a way to check it first using this link: http://koodomobile.com/en/on/switch2k...
Once you're sure it's compatible and unlocked, just pop in the appropriate koodo sim.
You may need to buy a new sim depending on what sim you have now.
If you're a new customer, you'll get a new sim when you start your service. You'll also get 10% off your monthly bill for bringing your own device! Best of all, koodo doesn't do activation charges!
Hope it all works! Welcome to Koodo
