I have been having echo problems on other end of call withh Samsung Galaxy S4,anyone else have this problem?
  • 3
Photo of Kenneth MacDonald
Kenneth MacDonald
  • 3
Photo of Jonathan I
Jonathan I, Mobile Master
Is it only with one person or multiple people?
Photo of Adnan Bashir
Adnan Bashir
  • 60 Points
I am from Pakistan and i am also experiencing the same Echo Problem. Its not a carrier problem it started when i updated my phone to 4.3. May be the adapt sound option makes it happen or some other new feature but i am sure that the problem stared after updating the phone to 4.3
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,100 Points 100k badge 2x thumb
No haven't had echo in Calls at all on my S4. Have you played with the adapt sound feature in the call settings?
Kenneth MacDonald
The echo is with everyone that I call,I have tried volume settings,unchecking the background noise and playing the adapt sound feature,tried soft etc..,no difference.love the phone but I am not going to keep it because of this.
Photo of Pat
Pat
  • 320 Points 250 badge 2x thumb
Some case create echo. Remove it and try again.
Photo of Greta
Greta
  • 60 Points
I am having the same problem. I'm on my 3rd phone and it's still doing it. I've tried with and without my case and it still does it.
Photo of Gery
Gery
  • 60 Points
this is a bug in hardware design (at least it is in the s4 ACTIVE) , remove the back cover and echo dissapears, change your s4 Active for something else
Photo of Khadafi
Khadafi
  • 60 Points
I have the same problem. When I remove the back cover of my phone, the echo stops and when I put it back it still the same. Help me please.
Photo of Lynne Lyons
Lynne Lyons
  • 80 Points 75 badge 2x thumb
My s4 was giving the same symptoms, turned out the mic hole on the bottom of the phone was blocked up, once cleaned with a fine needle all was good again
Photo of jamtrip
jamtrip
  • 62 Points
Thanks Lynne Lyons! You were the only one that posted this as a possible cause (I scoured many pages).
