I have an unblock Samsung Galaxy S4- it will not send picture messages? please help
Photo of Cinny
Cinny
  • 132 Points 100 badge 2x thumb
Photo of quasarito
quasarito
Please make sure you have the proper APN settings configured on your phone:
See http://help.koodomobile.com/plans-add...
Photo of Cinny
Cinny
thanks.. I will try this...
Photo of Rocky Balboa
Rocky Balboa
Let us know how it goes!
Photo of Cinny
Cinny
well..i followed exactly and it saved correctly and I restarted my phone, i sent a test picture to a friend and it still says its sending (for past few mins) :(
I guess I'll go after work and bring it in to see if they can get it to work...
thanks again for your help.
Photo of Myke
Myke
You have Mobile data turned on?
Photo of Cinny
Cinny
not sure where to check...
Photo of Myke
Myke
Settings > Data Usage > Mobile Data is the first option, should be set to on.
Rocky Balboa
Settings,data useage and mobile data make sure it is checked. Also if it is after you setup the APN to unplug the battery and sim card for 15 seconds plug back in and try again.
Photo of Cinny
Cinny
I did but darn it wont work..thanks again for the help. I will go in and see someone in store
Photo of quasarito
quasarito
Are you using Hangouts to send your texts and mms on your S4? There is a known MMS issue with it: see http://mobilesyrup.com/2013/12/04/han...
It seems to have been fixed with v2.0.2 of Hangouts. See http://www.droid-life.com/2013/12/09/...
Do you have a data block on your account? Mms needs data.
