I have a Nexus4 phone that will not send pictures. My plan doesn't include data however it said free MMS. How do I fix this problem?
  • 2
I am not super tech savvy but is there an easy way to fix this problem?
I just got this phone a few days ago and am kinda disappointed that it doesn't send pictures without the data. I read something that the data could be turned on and it would not cost anything, however I am worried I will access it by accident through the apps or my apps will automatically update.
Please help! Thanks
Photo of carmenn
carmenn
  • 132 Points 100 badge 2x thumb
  • 2
Photo of John Burke
John Burke, Mobile Master
Mobile Data needs to be enabled to do MMS.
Connect to Wi-Fi before enabling Data so you won't get charged for Data usage.
Be sure you disable Mobile Data before you disconnect from Wi-Fi though.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
When you go into the Data Usage section of Settings, tap on the three dots in the upper right corner. Within that, there should be Restrict Background Data. Have that chekced off and that will eliminate some, if not most, of the background data.
Photo of carmenn
carmenn
ok so my choices are that i have to be in a wifi zone to be safe when i turn on my data. I did restrict my background data (thanks!!) so if i do turn on my data because i need to send a picture it should hopefully stop some of the background data
Photo of carmenn
carmenn
too bad there is no way to have my data turned on but only set it so it for MMS
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,726 Points 100k badge 2x thumb
You can TRY this: http://community.koodomobile.com/kood... but it's not guaranteed and may not work on your phone.
Photo of B2theden
B2theden
  • 2,626 Points 2k badge 2x thumb
Hey I always share that. Lol
Photo of Brendan William
Brendan William
  • 732 Points 500 badge 2x thumb
Turn on mobile data
Zaphod Beeblebrox
I guess you didn't read the other posts before you said that, eh?
