I have a 5 dollar balance. .. what does this mean and how can I use it for a boost
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
Photo of Tracy Parkinson
Tracy Parkinson
  • 80 Points 75 badge 2x thumb
Photo of Angela
Angela
  • 488 Points 250 badge 2x thumb
If you have a 5 dollar balance on your koodo prepaid you can go online to your self serve you can only add 25 any time minutes for $5. You can also go throw *611 and add the booster throw there as well. hope this helps have a great day
Tracy Parkinson
I'll give it a try ... thanks
Photo of Sophia
Sophia, Mobile Master
Hi Tracy, here's a tip for you :) Yes you can use your $5 to get a booster, which will indeed give you 25 minutes call time.
But if you add $20 more to your account, you can add the $25 booster to your account instead.
Difference is this one will give you 500 minutes... which means you only pay $0.05 per minute instead of $0.25 with the $5 booster. They both carry over as long as you keep your base plan active!
