I don't receive incoming calls on my prepaid. I have a talk booster.
Photo of Jack Doe
Jack Doe
Photo of tlee1973
tlee1973
  • 634 Points 500 badge 2x thumb
when you activated the talk booster was your base plan topped up? when you buy a virtual pin and top up your account it will automatically top up your base plan first then you can go ahead and buy a booster.
Photo of Brittany Behenna
Brittany Behenna
  • 310 Points 250 badge 2x thumb
As well, if your base plan is topped up, when adding in the virtual pin, you must select exactly was booster you want, then you should be able to receive calls during the day
