I CAN'T USE MY PHONE, NOT REGISTERED ON A NETWORK
  • 6
  • Updated 1 year ago
  • Doesn't Need an Answer
I had my Samsung Galaxy Ace phone from Koodo less than a month ago. This morning when I tried to call my friend it says not registered on a network. I tried to pull the battery and sim out but it did nothing. I asked my friend to call my number but it goes directly to my Voicemail. I just couldn't use my phone. What can I do?
Photo of Lotus Avie
Lotus Avie
  • 6
Photo of John Burke
John Burke, Mobile Master
Did you try:
-manually searching for & selecting the Mobile Network "Telus" or "Koodo"?
-resetting the APN to Default?
Photo of Janie Rankin
Janie Rankin
  • 102 Points 100 badge 2x thumb
Bell Samsung 4 says not registered when I call my friends
Janie Rankin
Also the koodoo cell I had I paid of my bill plus tab and also sold to a friend why then is this cell still activated when they have their own card in it
Janie Rankin
9023023408
Janie Rankin
Bell 9926314249
Photo of Mayumi
Mayumi, Mobile Master
  • 113,750 Points 100k badge 2x thumb
Hi, Janie.
Is your Bell phone unlocked?
Also you sold your Koodo phone to your friend. Is your friend with Koodo or different service provider?
If you can post new question, you will get answer/help quicker.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,110 Points 100k badge 2x thumb
Make sure the phone didn't accidentally get set to 2g or GSM only in the network settings. Also make sure that you didn't accidentally turn on airplane mode, press and hold the power button like you were going to turn the phone off and when the options come up make sure where it says airplane mode that it doesn't say on. If it does say on tap it to turn it off.
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Lotus, let us know if you were able to get this resolved. Thanks.
________________________
Mine does the same thing! It display s Koodo on my screen but I can't use it as I'm not registered on the network ... Of course the koodo system is upgrading and customer service is closed :(
Photo of Mayumi
It could be your sim card.  Did you try to take a sim out and put it back in?
I had a same trouble a few days ago. I took sim card out and in more than few times and I got connected again.
It's back working again! Thank you :)
Photo of Jay Abel
Jay Abel
  • 92 Points 75 badge 2x thumb
Mine is only working sporadically, mostly not working.  When I say "select network provider automatically" I immediately get a message "registered on network".  But then when I try to call, "not registered on network."  Maybe I shouldn't have chosen Schrodinger's network.
Photo of Donald Brooks
Donald Brooks
  • 72 Points
I would like to register myphone
Photo of David
David, Mobile Master
  • 91,466 Points 50k badge 2x thumb
Are you a Koodo customer already? If not, you will need to stop by a Koodo store to obtain a SIM card & instructions to set it up.
Donald Brooks
  • 72 Points
I would like to register my phone
