I can only send/receive picture messages from other iPhones, not from a Samsung
I can only send (and receive) picture messages to friends with iPhones, not to friends with Samsung's. My son has an iPhone and it works for him so I am not sure what the problem is with mine. My phone was unlocked using a sim, not sure if that's a problem. Any thoughts?
Photo of Brenda Bell
Brenda Bell
  • confused
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Hi there Brenda... Make sure all the settings are the correct ones... Here is the link to set up your data and mms on Non-Koodo devices... Hope this helps...
http://koodomobile.com/en/ab/non-kood...
Brenda Bell
I am going to give this a try later today, fingers crossed.
Photo of Ahmad
Ahmad
Have you blocked your data and are only using WiFi?
You need to have your data enabled in order to send/receive picture messages to other regular smartphones. For being able to send/receive between iPhones, that's because iMessage can run off WiFi. If you were to disable iMessage, you wouldn't be able to send/receive pictures from iPhones either.
Brenda Bell
Data is on and I have the same issue whether I am on Wifi or 3G. I have some suggestions regarding settings and APN, I'm going to give those a try today
Photo of Courtnee
Courtnee
  • 396 Points 250 badge 2x thumb
For my phone to send and receive pictures you need to have your data on (3G/4G)
Brenda Bell
Data is on.
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Brenda, by chance is it Imessage that's being used? As that will only work between Iphones.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
The iphone does have a separate switch to enable mms messaging. If that's off it could explain why you can send to iphones using imessage but not to any other devices. I think it's under settings->messaging.
