I am a Koodo customer. My current phone does not work. Can I use my old telus lg keybo 2 until I decide on a new phone?
My lg keybo2 was on a tells prepaid plan. There is no SIM card
Photo of Mistelbacher StevenWendy
Photo of Daniel Kim
Daniel Kim, Mobile Master
I'm not too familiar with that phone (whether it is CDMA or not) and what do you mean no sim as in no sim slot or your sim doesn't fit?
but if it has a sim card slot,
you can get a new koodo sim in the appropriate size for 10 on postpaid and 20 on prepaid. Then you can switch the sim cards via self serve.
Some telus phones work on koodo without unlocking so insert the sim and see if it works. If it doesn't, you'll need to get the keybo 2 unlocked somehow, possibly through cellunlocker.net or another 3rd party service.
Remember that if you want to use your old sim you'll have to swap sim cards through self serve within 90 days just in case the new phone you're getting uses the same sim size.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
The keybo was a CDMA phone. A Telus keybo will not work on koodo.
