i added a data booster to my phone and it's not working?
  • 3
I just used my credit card and added 30$ to my account then i added the booster, why is the data not working on my phone?
Photo of Amanda Winter
Amanda Winter
  • 3
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
is the data turned on?
Photo of Sophia
Sophia, Mobile Master
Also, if your phone was not a Koodo phone originally, can you check if your APN is set up correctly?
http://help.koodomobile.com/plans-add...
Amanda Winter
data is turned on, i turned off phone and turned on again. It's an unlocked phone.
Photo of Jonathan I
Jonathan I, Mobile Master
  • 114,364 Points 100k badge 2x thumb
What kind of phone is it? Blackberries running OS 7 or older are not eligible for prepaid data.
Did you check the link Sophia posted? Without those numbers in your phone, you won't be able to use data.
Amanda Winter
omg sophia, You're a genius thank you so much for that link!!
Photo of Sophia
Glad you got it working :D
