I want to make international call (from canada to Mauritius) ,how much it will cost me per minutes.
  • Updated 3 weeks ago
  • (Edited)
Photo of Christophe Saint-paul
Posted 3 weeks ago
Photo of Dinh
Dinh, Mobile Master
  • 28,454 Points 20k badge 2x thumb
Hi Christophe,
You can check your rate here: https://www.koodomobile.com/help/long-distance-calling
There are 2 rates, one is the normal rate. The other is the rate with $3 International Long Distance Saver.
Photo of Mats
Mats
  • 8,286 Points 5k badge 2x thumb
It is a $1.00 a minute.
The $3 Long distance saver add-on only saves you .5 cents a minute to Mauritius. Thought that add-on saved you more than that.
Photo of Allan
Allan, Mobile Master
  • 54,230 Points 50k badge 2x thumb
It depends on the place. China for example goes from $0.50 to $0.05/min with the add-on.
It's for Mauritius which found in the Indian ocean. Where I can find the rate for each country.
Photo of Dennis
Dennis, Mobile Master
  • 182,206 Points 100k badge 2x thumb
Just use the link Dinh provided and there is a drop down to select countries
Thanks for this info,I got it
