i turn my cel on and it does not stay on
  • Updated 2 years ago
lg-k121
Photo of Ferne Ethier
Ferne Ethier
  • 220 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
What cellphone is it? Edit oh, I see what you posted. Well let's begin basic troubleshooting... Is it charging?
Ferne Ethier
yes
Photo of Goran
Goran, Mobile Master
  • 97,236 Points 50k badge 2x thumb
At what point does it usually turn off? And you mean off not restart ? Does it ever restart as well ? Have you noticed if it gives a low battery warning first or is it sudden? Do you have anything in particular you are doing ? Does it happen at a certain battery level? If the battery is removable can you check if it's fitting loose?
Photo of rikkster
rikkster, Mobile Master
  • 68,314 Points 50k badge 2x thumb
The battery is removable. Remove the battery and set it on a flat surface. Inspect the battery casing for warping, bulges or cracks. Inspect the battery compartment for any signs of battery gel leakage. If you find any of these defects, do not charge the battery. You should be able to get a warranty replacement battery through Koodo if the battery is defective.
If the battery passes inspection, do you have a tight fitting phone case installed that might be pressing on the power button and turning the phone off?
