How do I change my plan?
  • (Edited)
How can I change my plan? What is prepaid? Is prepaid possible if I have a 'tab'?
Perhaps I should just pay off the tab & get out of Koodo?
Photo of Loreen Kenny
Loreen Kenny
Posted 3 years ago
Firstly if you're on a tab then you aren't on prepaid.
If you're on tab small or medium you can change your plan for whatever plan suits your needs at any time (once per bill cycle) you're never locked into.a plan.
Unless you're on tab large. And then you can only select from tab large plans.
All of this can be done via self-serve for free.
Photo of David
David, Mobile Master
  • 89,190 Points 50k badge 2x thumb
If prepaid is enough of a saving for you, it may be worthwhile to pay off your Tab, so you can switch to the prepaid option. As always YMMV.
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
Here are all the monthly plans : https://shop.koodomobile.com/plans/pl...
All prepaid info : http://koodomobile.com/en/on/plansand...
And you do not need to get out of Koodo. You need to consider other plan options!
Photo of BobTheElectrician
BobTheElectrician
  • 62,094 Points 50k badge 2x thumb
You can opt for a minimal plan and add unlimited calling or incoming if that's all you need. Check out the monthly add-ons.
