I switched my plan and can't get data to work. Help please
  • Updated 2 years ago
I recently switched my phone plan to the $30 plan to have 100 mb of data. But I can't get it to turn on. When I select to turn on data, nothing happens. What am I doing wrong?
Photo of Sarah Clark
Sarah Clark
  • 164 Points 100 badge 2x thumb
  • annoyed
Posted 2 years ago
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
If you just changed it, it's possible it needs an hour but not usually. Turn on airplane mode and turn it off then reboot the phone.
Sarah Clark
I changed it yesterday and tried all of that. When I turn it on it doesn't work
Photo of Goran
Goran, Mobile Master
  • 97,682 Points 50k badge 2x thumb
Do you have a data block on your account? Switching to a plan with data will n automatically remove it.
Sarah Clark
I'm not sure, how do I find that out?
Photo of Goran
Check your self-serve for a data block MMS only add-on I it's there. If data is on in your phone and network mode is set to include wcdma and LTE and that add-on is not on then you will likely need to contact Koodo to have a data block that y cannot see removed.
Sarah Clark
Okay I will have to try that. Could that have something to do with the fact that it is a second hand phone maybe?
Photo of Robert
Robert, Mobile Master
  • 106,940 Points 100k badge 2x thumb
Not really.
Photo of Goran
Also be sure to check for your APN settings that they match this :
https://apn-canada.gishan.net/setting...
Sarah Clark
Sarah Clark
Is that right?
Photo of Goran
  • 97,308 Points 50k badge 2x thumb
Looks good. If its still not working then restart your phone, pull your Sim card ou and in. If sti nothing to resetting network settings via step 6 here:
https://support.apple.com/en-ca/HT201415
It will erase wi-fi networks saved and check APN settings afterwards.
Photo of Robert
  • 107,602 Points 100k badge 2x thumb
Have you checked if you had a data block on? Did your last plan have data or not?
Sarah Clark
Thank you everyone who helped. I called Koodo and it it was a data blockage. It's all figured out and works now, thanks
