I need more data. Koodo has options to increase the $ value of my plan. When I click on a higher value I get offered stuff I don't want.
  • Praise
  • Updated 1 year ago
Photo of BLewis
BLewis
  • 270 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
If you are on a shock free data plan, there will be options for you to buy more data once you have used 100% of yours that will be good until the end of the billing cycle. Otherwise you can upgrade your plan. https://www.koodomobile.com/rate-plan...
If you are on prepaid you can simply just buy a data booster.
Photo of Lloyd Willett
Lloyd Willett
  • 3,394 Points 3k badge 2x thumb
I wish koodo offord call forwarding to month to month for free like they do on prepaid plan
Photo of Dennis
Dennis, Mobile Master
  • 187,078 Points 100k badge 2x thumb
Call forwarding isnt free.  It still uses your minutes
Photo of BLewis
BLewis
How sensible! Thank you !
