I need help connecting to the network. My phone is still searching two days after activating my account on line
  • Updated 11 months ago
Photo of Whyda Hault
Whyda Hault
  • 90 Points 75 badge 2x thumb
Posted 11 months ago
Whyda Hault
Just to add I have an iPhone 6 and tried turning phone on and off (several times since yesterday), airplane mode is off, I took SIM card out and replaced it just in case and still getting searching in the top left hand corner.
Photo of David
David, Mobile Master
  • 89,482 Points 50k badge 2x thumb
The phone is a Koodo phone, or unlocked if from another carrier?
It is possible you have a bad SIM. Can you return to a Koodo shop and have it and your phone checked?
Whyda Hault
Hi yes it's an unlocked phone but I travel and use this phone all the time so I know it's not the phone. I see under carrier it says Koodo and same under data so it's confusing as to why I can't connect to the network
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Hi whyda, try going into your settings and resetting the networks settings.
Reset your Network Settings. Go to Settings > General > Reset > Reset Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
