Changing Phone Plan!!
  • Updated 5 months ago
  • (Edited)
I am from Nova Scotia and trying to change my plan to the $45.00 with 2GB, I have an old plan now so I'm a little scared to change it and not be able to keep the plan I have If I can't have this new one but in the Nitty Gritty it says "Rate plan available for Manitoba and Saskatchewan residents with Manitoba & Saskatchewan area codes only. Subscribers moving to another province will be transferred to an applicable rate plan for that location. Rate plan available for Quebec residents with Quebec area codes only. Subscribers moving to another province will be transferred to an applicable rate plan for that location."  I also have my region set to NS so does this mean I can't have the $45.00 plan if I'm not from these places? Just super curious on what this message actually means since it even shows up when you are just shopping for plans!!
Photo of Melissa Burns
Melissa Burns
  • 200 Points 100 badge 2x thumb
Posted 5 months ago
Photo of Bernard
Bernard, Official Rep
  • 81,124 Points 50k badge 2x thumb
You are good to go Melissa! The restriction is for other plans.
Photo of Allan
Allan, Mobile Master
  • 62,876 Points 50k badge 2x thumb
The nitty gritty has numbers assigned to it to refer to the numbers on the descriptions of certain plans. (If you set your region to Quebec you will see different plans that arent available to you) You are good to get the $45 plan in Nova Scotia.
Melissa Burns
Okay! Sweet, I'll go ahead and do it. Thanks so much!!!
