I migrated to the $60 plan. My phones are working, but the data is not !! Please help !
  • Updated 7 months ago
60$ plan data not working
Photo of Malcolm Ponnayan
Malcolm Ponnayan
  • 102 Points 100 badge 2x thumb
Posted 7 months ago
Photo of Dinh
Dinh, Mobile Master
  • 42,206 Points 20k badge 2x thumb
Hi Malcolm,
Have you checked if your mobile data was set to ON and the APN was set to https://www.koodomobile.com/help/setting-data-your-non-koodo-phone
I would also suggest you reset the network settings, restart your phone and see if it helps.
Malcolm Ponnayan
Thank you so much Azure123. It was a non koodo phone and I followed the instructions and now it is working ! Thank you again. Much appreciated :)
Photo of Dinh
Dinh, Mobile Master
Glad it helped you!
Cheers
