i keep turning on my bluetooth but it keeps turning off and not finding any devices to connect with i have a motorola g4 phone
  • Updated 10 months ago
each time i turn on bluetooth it says it is disabled i have the motorola g4 phone it used to connect before but now doesn't work after updating
Photo of John Ledgerwood
John Ledgerwood
Posted 10 months ago
Make sure that no power saving mode is enabled. Start by turning the Bluetooth on your device off and back on again. If the problem continues, clear the cache for Bluetooth by going to the Bluetooth Settings. Restart the phone after clearing the data and cache.
Source:
http://www.androidauthority.com/lg-g4...
Photo of Pierre Larocque
Pierre Larocque
  • 80 Points 75 badge 2x thumb
Ok mine does the same.  Im glad its not just my phone.  I am going to call them today to see what they can do.  If i hear anything i will let you know
Also found this.
Pierre Larocque
Nope still no bluetooth
Pierre Larocque
i turn bluetooth on then more settings and its says off i switch to on but the circle wont light up it swipes over but nothing happens.  Your update broke my new phone.  I need bluetooth its an important feature on the phone
Photo of Jru Gordon
Jru Gordon
  • 9,144 Points 5k badge 2x thumb
it's not Koodo's update that broke the phone.
Try the following steps
Go into:
  • Settings
  • Google
  • Security
  • turn off Google Play Protect
Go back into:
  • Settings
  • Applications
  • click on the 3 dots in the Top-Right of the settings
  • reset App Preferences
next go into:
  • Settings
  • Storage
  • Clear the Cache
Finally, power cycle phone (turn it off and back on)
