I keep getting empty voicemails without actual calls.
  • Updated 2 years ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
I'm using an iphone 5s with a 300 min plan. I have got repeated voicemails for a couple of months now that are empty and for which there is no recent call record. The phone doesn't ring for these. The voicemails are usually short and silent when I check them. These functions all work normally otherwise. It's very annoying, how do I get it to stop?
Photo of David
Posted 2 years ago
Photo of BobTheElectrician
  • 57,518 Points 50k badge 2x thumb
Do they show an originating number? Could be telemarketers/scammers/robocallers trolling for numbers.
Photo of David
No, that's the thing, there is no incoming call or number logged in my recents.
Photo of Robert
Robert, Mobile Master
  • 101,484 Points 100k badge 2x thumb
Do you have do no disturb mode activated? Sometime call go directly to VM with that option on.
Photo of Anna
  • 6,126 Points 5k badge 2x thumb
Hey David? Did you check the Do Not Disturb setting like Robert suggested? Let us know! :)
Photo of David
All the Do Not Disturb switches were off except for the Repeated Calls one. I have turned it off now. But it seems to me that even with DND on an incoming call would be logged, right? And whoever called would actually leave a message. I have been getting other calls. This feels like a glitch in Koodo's voicemail system, like it's not actually coming from a phone call. I just had my sister call and leave a message and everything worked the way it is supposed to, but I expect there will be more of these call-less empty messages.
Photo of rikkster
rikkster, Mobile Master
  • 66,412 Points 50k badge 2x thumb
Are you able to see any activity on your phone bill? (An incoming phone number that you do not recognize and where calls are short in duration). Using this method, you might be able to find out where these calls originate.
Photo of David
These calls don't seem to be showing up on my phone bill either.
Photo of David
So, none of these helpful suggestions has identified the cause of the problem I have (or its solution), and I continue to get these empty voicemail messages (one yesterday, another one today). I can't seem to find any actual customer support number/email for Koodo, is it the case that Koodo has no customer support?
Photo of Jru Gordon
Jru Gordon
  • 9,018 Points 5k badge 2x thumb
1-866-995-6636 is Koodo's Customer Support Number.
Photo of Alicia
  • 60 Points
I've had this issue as well. I always get the calls at the same time of day and there is no logged missed call or anything.
Photo of Melissa
Melissa, Employee
  • 11,708 Points 10k badge 2x thumb
Hey Alicia! Have you perhaps added a number to your do not disturb list or blocked a number from calling you? If so, the call will not be shown on your phone but the person can still leave a voicemail.  Keep us posted!
