I have not exceeded my call minutes, however I am being charged for a portion of them.
Photo of Wesley Karn
Wesley Karn
Posted 3 years ago
Photo of frananddave
frananddave
  • 992 Points 500 badge 2x thumb
Any calls to U.S.?
Photo of Fiset
Fiset
  • 260 Points 250 badge 2x thumb
Have you used call forwarding? Without the 3$ add-on, call forwarding minutes are charged per minutes.
Photo of Mathieu Carrier
Mathieu Carrier
  • 4,124 Points 4k badge 2x thumb
How are you confirming that you did not go over your minutes?
Photo of Karine
Karine
  • 2,422 Points 2k badge 2x thumb
Hi Wesley! Do you recall changing your rate plan in the middle of your billing cycle? If yes, then this is proration.
frananddave
Yes! This is an issue that is waiting to surprise folks. When we change our plan, they check to see whether we have exceeded the pro-rated amount for that amount of the billing period. One has to plan wisely before changing plans in order to avoid charges.
