I have no data service for S6 Edge phone
I can make calls but no internet
Photo of xing2000
xing2000
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,110 Points 100k badge 2x thumb
Did you enable data within the settings of the phone?
Make sure you have Koodo's paper APN settings set up and selected.
Here's Koodo's APN settings below
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save. Make sure the radio button is selected to activate data. The frequencies are compatible so it should work.
Did you purchase any data boosters? If not then you'll have to make that purchase
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,996 Points 10k badge 2x thumb
Paul pretty much aced it, but one other small mistake i see people make is that they add the money into their account for a booster, but dont actually buy the booster with the money.
Call *611 and press 3 for a review of your current boosters
Photo of xing2000
xing2000
Problem fixed. I didn't have the Proxy and port numbers in my phone. Thanks a lot.
