I have lg k4 and even tho I have 16gig sd card idk how use sd card 120$ fo phone to get a new one
  • Updated 2 years ago
I have lg k4 and even tho I have 16gig sd card idk how use sd card there's no option to so I need help or curious if I could just pay out the phone since it's only 120$ for phone to get a new one
Photo of Justine Mctaggart-burns
  • 150 Points 100 badge 2x thumb
  • confused
Posted 2 years ago
Ok sorry for anyone reading this I just wanted to say about how to use sad card on my lg k4
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
What are you trying to use the sd card for?
Photo of David
David, Mobile Master
  • 89,024 Points 50k badge 2x thumb
Here is a manual for the phone. It appears the main use is to store photos and video.
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
To verify that the SD card is installed, go to: Settings > Storage - you should see the title; 'SD card', the amount of storage used and the total storage capacity of the SD card, minus a few megabytes. If inserting a used SD card, you may see a pop-up message to format the SD card. Provided there is nothing on this SD card you want to keep, select yes or ok.
To store photos/videos on the SD card, go to your Camera app and tap the Gear icon in the lower left corner of the viewfinder to open the camera settings menu. Tap the SD card icon. Choose from IN (internal memory) and SD (memory card). This menu appears only when the SD card is inserted.
