I have an LG4 and it seems to have weak signal in major areas of town (Ottawa).
  • Updated 8 months ago
I have an LG4 and it seems to have weak signal in major areas of town (Ottawa). I cannot understand why this would be the case Also, I can always hear the caller fine, but the problem seems around them not hearing me. Any ideas? The phone is about 6 months old and this has been an ongoing problem. Thanks for any advice
Photo of Mitch Bloom
Mitch Bloom
  • 80 Points 75 badge 2x thumb
Posted 8 months ago
Photo of Pedro Echeverri
Pedro Echeverri
  • 500 Points 500 badge 2x thumb
Hey Mitch,
If your phone is having these issues and it’s only 6 months old you might be covered under warranty to have your phone replaced.
Photo of Allan
Allan, Mobile Master
  • 62,502 Points 50k badge 2x thumb
Have you tried simply restarting your phone and reinserting your SIM card?
Mitch Bloom
Thanks and yes I did that as well as tried the different settings recommended
Photo of Allan
If you have another phone or a friends phone that you can swap sims with then try that and see if the problem still occurs.
If you don't have access to another phone you can go into a Koodo store and have them test your SIM for you.
If it works fine in another phone then you likely need a new phone. If it doesn't work in another phone then the problem is likely the sim card.
