I have a wireless home phone hub and a couple days ago my phone doesn't ring when someone calls
  • 2
  • Updated 10 months ago
Photo of Darlene Porter
Darlene Porter
  • 90 Points 75 badge 2x thumb
Posted 10 months ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
Did you check the phone that you are using it with for ring and volume?
Darlene Porter
Yes the phone is working the ringer and volume is turned up
Photo of David
David, Mobile Master
  • 93,788 Points 50k badge 2x thumb
Have you tried turning the device off, then on again, or any of the other troubleshooting steps in the manual?
