I have a telus phone but with a rogers phone can I swith to koodo with my current phone. what about my #, can I port an aviable landline.
  • Updated 2 years ago
I have a telus phone but with a rogers plan. can I keep my rogers number to go on koodo prepaid. or better yet can I port my old landline as it still shows avaiable. as with everyone I want an easy number as it is for business.
Photo of Adrian Currie
Adrian Currie
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Yes if your phone is already unlocked (or in this case a Telus device) then you can use it on Koodo and port your number over just get a koodo prepaid SIM that fits your phones and activate it and you can port the number over during activation.
Adrian Currie
I meant to say rogers plan.  did you say yes to ported my old landline?
Photo of Dennis
Dennis, Mobile Master
If it is a rogers phone, the phone will need to be unlocked before it can be used with Koodo.
Here is more info about porting your number
http://help.koodomobile.com/getting-started-with-koodo/moving-your-number-to-koodo-new/how-do-i-move...
My understanding is the phone number is yours.  No matter who you are with.  Customer Service (any company) may try to fight your request but it is a CRTC law that you can take your phone number with you. I have a friend who is now in BC with a NE Ont. number.
Adrian Currie
Yes thanks your right.  I just had it tested at a koodo pavillion and it works fine on their network ll I need is a SIM card from koodo and I am good to go.  Thanks again.
