I have a problem with my new LG G5...
  • Updated 1 year ago
I have a problem with my new LG G5....the power button stopped working..fingerprint recognition as well. I am aware it is common, could be upgrade related or simply the contacts inside the phone are dirty. Anyone else have this problem yet?
Photo of Rye Tye
Rye Tye
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 91,426 Points 50k badge 2x thumb
Not sure what you mean by upgrade related. In case you need more info:
http://help.koodomobile.com/getting-s...
Photo of Rye Tye
Rye Tye
Along with the possibility of the contacts being dirty..I read that it could also be software related ..meaning a recent upgrade has a bug that either disables it or causes problems..the button doesn't work when u depress it..but why wouldnt the fingerprint recognition work..since your only slightly touching it?
Photo of Goran
I haven't looked into possible causes of the issue. If a factory reset doesn't fix it, you're under warranty, and I'd make use of it if you have your power button no longer working either.
Photo of Rye Tye
Rye Tye
Thanks alot for your help..just wanna make sure its not a recurring problem before replacing my phone....the problem seems to be all over the internet...ive only had it for 3 weeks..
