I have a problem in connecting hot spot i try everything what can i do?
  • 2
  • Updated 2 years ago
Photo of Lovely Baina
Lovely Baina
Posted 3 years ago
  • 2
Lovely Baina
When i try to open my hot spot using Note 2 & But it didnt connect. my android tablet even in my ipad. What can I do? I follow all the step but still not working.
Goto settings... Wireless and networks... More... Mobile network... Access point names
Select koodo
Press the menu key and choose edit
Add 'DUN' without the quotes to APN Type.
Press menu key
Choose save
Photo of BobTheElectrician
BobTheElectrician
  • 61,920 Points 50k badge 2x thumb
Tethering (hotspot) on Note 2 used to work fine when I was on monthly, plan but not since I switched to prepaid.
Lovely Baina
I still didn't get your answer about the hotspot
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi there, are you still experiencing issues with the hot spot? Do you have the latest software update? Also, is it a Koodo phone? Thank you!
