I have a Nexus 5 phone. I have rebooted it twice. My daughter and wife have Koodo serrvice as I type this, but I do not. Help.
  • Updated 11 months ago
Photo of ruben christana
ruben christana
  • 90 Points 75 badge 2x thumb
  • frustrated
Posted 11 months ago
Photo of Sophia
Sophia, Mobile Master
  • 143,064 Points 100k badge 2x thumb
Are you all on the same account? What happens if you swap Sim cards?
ruben christana
no.  different accounts
Photo of Sophia
Can you try one of their SIMs in your phone just to make sure it's not the phone?
ruben christana
tried.  doesn't work
Photo of Allan
Allan, Mobile Master
  • 62,836 Points 50k badge 2x thumb
Can you try manually selecting a network? Settings, Mobile Networks, Network Operators, Select Manually.
Photo of rikkster
rikkster, Mobile Master
Another option; try resetting network settings on your LG G5.
Go to: Settings > General > Backup & reset > Network settings reset > select RESET SETTINGS - tap Reset Settings to confirm.
Photo of Jan Hope
Jan Hope
  • 4,356 Points 4k badge 2x thumb
Hi Ruben Christina,
First of all you have to determine if there is no problem with your phone. In order to do this like @ Sophia said swap Sim cards with your daughter or wife or if your phone is unlocked, with any other active Sim card.
It is sometimes strange an funny because when I post something there is no response yet and then it appears that someone responded before me. I couldn't know that and see.
