I have a Nexus 4, - 4.2.2 Koodo phone and i am unable to connect to WiFi
Koodo Nexus 4 4.2.2
Photo of sheila higgins
sheila higgins
Posted 3 years ago
Photo of Todd Leblanc
Todd Leblanc
  • 880 Points 500 badge 2x thumb
Small list of trouble shooting for you to try
Restart the phone
Make sure the phone isn't in airplane mode
Turn the modem off and back on
Turn your Wifi on your phone off and on
And if all else fails reset your device
Hope this help let us know if none of the above helps
Photo of BobTheElectrician
BobTheElectrician
  • 67,286 Points 50k badge 2x thumb
If your router is a DLink, check their site to see if a firmware update is available for that model.
sheila higgins
Thanks. Its a rental from my provider. A 2/1 combo. Internet and WiFi for computer combined..
BobTheElectrician
Contact your provider, especially if it's a DLink, after trying the following:
Get out of the house a ways, go into airplane mode, the turn wifi back on. tap on the wifi lnk you normally use and choose "Forget". Go back home and reconnect from Ø.
Todd Leblanc
It's more then likely not a dlink as dlink doesn't really have carrier supplied routers as far as I'm aware
sheila higgins
Todd, i tried your suggestions and something worked! Now i have WiFi connection and can take care of my 'upgrades'. Thank you so much for your help. S.
