I have a mobile phone with 3 add-ons. How does this work with the "$5 a month for a year plan" ? Can I only use the main phone/hub to con?
  • Updated 4 months ago
I have a mobile phone with 3 add-ons. How does this work with the "$5 a month for a year plan" ?? Can I only use the main phone/hub to connect with your hub?? I can see that the connection is via 2 ?phone?ends...I still have to plug My hub in too... same with the 3 other add-on hub/phones. Will I be able to use these 3 in the same way ??...you know..1 in each room.....
Photo of Jullin Paynter
Jullin Paynter
  • 142 Points 100 badge 2x thumb
Posted 4 months ago
Photo of Goran
Goran, Mobile Master
  • 97,450 Points 50k badge 2x thumb
Well you would plug in your main station / receiver for your wireless phone set and the rest just go wherever and will also get the call like with a landline phone.
Photo of BobTheElectrician
BobTheElectrician
  • 67,528 Points 50k badge 2x thumb
The $5 a month plan is only for the phone(s) connected to your base hub. That's meant to connect to a conventional corded phone or a base station for cordless phones. Anything connected there is covered at the $5 monthly rate.
It doesn't extend to other cell phones that you may have. Those still have their own independent plans.
