I have a LG G3 When on gss/wcdma/ auto i my call bars drops low and loses the signal.
  • Updated 2 years ago
I have a LG G3 i noticed when i put the network on gss/wcdma/ auto i my call bars drop to 1 then loses the signal. When i set it to gsm/wcdma auto i get 3 to 5 bars. I already had my phone replaced 3 times with all the same issues. I guess im left wondering is it the phone or something else?
Photo of Darren Davidson
Darren Davidson
Posted 2 years ago
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
Your phone has to be set as GSM/WCDMA/LTE
It doesnt have to be. But this is what my LG G3 is using on Koodo at the moment and mine works fine.
Darren Davidson
Thanks for the reply!
I only have the auto when it's on it my signal is very weak this is another phone that I received from replacement warrenty org. So I'm just making sure if it's the phone or not.
As you see in the pic I have 1 bar.
Thanks
Darren Davidson
I forgot to say that I had my 1st cell for 8 months and never had a problem like this. I'm in the same areas as I was with my original but now issues with the signal.
Thanks again
Darren Davidson
Thanks for the input now I can return the other phone back. I just needed to know if it was a normal for LG G3 and the phone was fine.
Thanks again
I've been pulling out my hair over this, lets just say it was a rollercoaster kind of week. :-)
By the way I'm in Windsor.
Photo of Chadwick
Sorry its been a rough week Darren. Glad your getting it worked out. Don't hesitate to post again if you have any other questions.
Darren Davidson
Thanks
When in doubt, then check the Koodo community, Where you may just find the answers, you were looking for!
Photo of Jru Gordon
Jru Gordon
  • 9,038 Points 5k badge 2x thumb
Chadwick, I work 15 minutes south of London, and live 15 minutes east of where I work.  Also anytime I set up a customer's phone, or adjust the settings in a phone to take it off LTE, it increases the signal quite a bit, especially on Rogers/Fido
Photo of Chadwick
Like I said I'll try it. But u can't get better than full bars which I have almost always. So no point in changing it lol
Photo of rikkster
rikkster, Mobile Master
  • 66,988 Points 50k badge 2x thumb
You can do one better by completely eliminating GSM, (GSM/WCDMA). Koodo doesn't operate a 2G GSM network. Essentially, the phone is searching for a non-existent network. 'WCDMA Only' will work just as well and may save a little battery in the process.
