I have a Lenovo s930 and it will not connect to Koodo
Photo of Sam Pollack
Sam Pollack
  • 90 Points 75 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
I checked the specs online... apparently it's a dual SIM phone and one of the slots has the 850/1900 frequencies required for 3G for the major Canadian carriers, including Koodo. Try putting your SIM in the other slot and test it again.
Also make sure airplane mode isn't on and you have 3G enabled on the slots.
Photo of Dennis
Dennis, Mobile Master
  • 196,508 Points 100k badge 2x thumb
Have you also tried pulling the battery and sim for a few mins and try again.
Has this phone ever connected to Koodo?
Koodo uses 3G HSPA+ 850/1900
http://www.gsmarena.com/lenovo_s930-5...
Looks like there are 2 models for this phone (1 will work with Koodo and the other one will not).
Is the phone unlocked? When you switch your network from automatic to manual, which carriers show up?
Sam Pollack
yes the phone is unlocked.
I tried the sim on both sides
manual scanning only shows rogers 2G(forbidden)
Photo of Dennis
According to bijoy, only the first sim slot is 3G and the second slot is 2G only.
http://www.gsmarena.com/lenovo_s930-r...
Try manual scanning with the sim in the first slot. Does it say Rogers 2G still?
If so then I dont believe your phone has the signal to work with the 3G network
Sam Pollack
Thanks for trying I guess its not going to work
Photo of Dennis
Sorry :(
