I have a data blockage on my account and no data with my plan. Am I Still able to send pictures and mms without being charged?
  • Updated 2 months ago
I cutrently have a samaung galaxy grand prime. I would like to be able to send pictures and also send long messages in one text to my friends. I have a plan that doesnt inckude data and we also went ahead and got the data blockage so i didnt acccuently turn it on and create a huge bill. Can I stillsend pictures with this blockage on? If so how and will it charge me extra.
Photo of Baby Gal
Baby Gal
Posted 2 months ago
Photo of Dinh
Dinh, Mobile Master
  • 24,236 Points 20k badge 2x thumb
Hi Baby Gal,
How did you block your data currently? by adding an add-on or doing it manually in your phone?
If you had the add-on (which cost $2) then you could enable mobile data in your phone and you can send MMS free. It is a simple way and don't require much work.
If you don't have the add-on, it will be little complicated, there was some long threads about it in the forum. It would require some manual modifications of APN in your phone.
Photo of Robert
Robert, Mobile Master
  • 101,484 Points 100k badge 2x thumb
There's a 3rd possibility as well. If you have a data block add-on which is free and blocks all kind of data, then you would need to remove that one in order to apply one of the above solutions.
