I have a bill problem. Koodo charge me wrong amount. How can I ask Koodo to change it ?
  • Updated 2 weeks ago
In my April bill, there is an additional usage charges Data&SMS for $5. I checked it inside, for the data usage list, there is no data record cost for a $5.
Can Koodo check and change about it ?
Photo of Bo David Lin
Bo David Lin
  • 210 Points 100 badge 2x thumb
Posted 2 weeks ago
Photo of Dennis
Dennis, Mobile Master
How you logged into your self serve and downloaded your detailed pdf e-bill to check this charge?
Bo David Lin
Ok, just checked that I didn't use 0.00 MB, but 0.001 MB.
Fare enough. Thank you, Dennis.
Photo of Goran
Goran, Mobile Master
  • 90,296 Points 50k badge 2x thumb
You can still send a private message to Koodo via Facebook Messenger or DM via Twitter to ask about removing it since it seems like it was a minor data leak or something to that effect. If 0.001MB, that's just 1KB
Photo of David
David, Mobile Master
  • 88,974 Points 50k badge 2x thumb
Yes, there often seems to be a few bytes of data used to 'handshake' when a phone first reaches out to a network. It may be connected too the 2G network still running in some parts of the USA. As Others have stated, Koodo usually refunds the amount upon the subscriber contacting them.
