I has problem with image on device
  • Updated 2 months ago
I created an image in Adobe Illustrator on my phone. I finished all the work. I started to saving it to right place, and application was closed, without reasons. After I didn't find many of my important data. Any suggestions...
Photo of jennhamilton
jennhamilton
Posted 2 months ago
Photo of David
David, Mobile Master
  • 88,964 Points 50k badge 2x thumb
If the App crashed before the file was saved, you are likely out of luck, unfortunately.
Photo of Jwoods
Jwoods
  • 60 Points
You can just repair damaged adobe illustrator file with the help of Google search, to choose some variants from the results or to check Illustrator Online Service out, it was found from search engine too.
