Hi, I had to change phone and wifi is working fine and calls and text but no the data, what could it be? Pls help
  • Updated 2 years ago
  • (Edited)
I had to change phone from blackberry to acer and wifi is working fine and calls and text but no the data  I just restarted the phone  and turned off a wifi and is the same, no data at all, it says not connected.
Photo of Maylin Denis
Maylin Denis
  • 134 Points 100 badge 2x thumb
Posted 2 years ago
You may have to manually configure the APN settings
Settings....wireless and networks... mobile networks....access point names
See if "Koodo.sp" is selected and or available
If not you'll have to create it
Photo of Sophia
Sophia, Mobile Master
Check if your APN settings are correct, Maylin. You can find the correct settings here: http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data-on-android/How-do-I-setup-dat...
Maylin Denis
Thank you both, yes I had to configure it manually but now is working!! Thank you soooo much!
