I gave my old phone to someone who is using it just for wifi and it just stopped working for them how do they get it back tup and working
  • Updated 3 weeks ago
Photo of AngieR
AngieR
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 90,316 Points 50k badge 2x thumb
Could you give more details please? We are unable to help from "it just stopped working." Also what phone is it?
Photo of AngieR
AngieR
It's a Samsung s4 they are telling me that it keeps coming up saying keeps showing ap not active what ever that means
Photo of AngieR
AngieR
And ap currently not in use. Doesn't phones work for wifi even if they are all paid off and not under a plan or connect to a phone number?
Photo of Goran
Ap? They said it spells "Ap?"
Yes phones do work for Wi-Fi.
Photo of AngieR
AngieR
Probably meant apps
Photo of AngieR
AngieR
Why would the phone just stop working for wifi
Photo of AngieR
AngieR
Is there a fix to get it back working for wifi?
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
This most likely is an internet problem and not a phone problem. If you get the user to connect the phone to a different wifi connection chances are it will work. If you dont feel comfortable doing some of the steps in the guide below than get your friend to call their isp to do it for them.
Here's a guide that may help get your sorted out:
http://techcody.com/ap-currently-not-...
Note: AP in the internet industry stands for access point.
Photo of AngieR
AngieR
Is there another easy way because they can't get that program to download on the computer they are using.
Photo of Allan
Thats not a program, thats a website. If they can't get it to load then that confirms that they are having internet issues and need to contact their isp to fix it.
Photo of Ivan
Ivan, Mobile Master
Could also be a problem with their router.
Photo of Linda Davenport
Linda Davenport
I was doing the same thing with my phone that was not hooked up to any cellular plan and I was only using it from my Wi-Fi and after about 5 or 6 months I started getting emails stating that I needed a cellular plan in order to use my Wi-Fi mind you I still kept using it have you tried pulling out all the plugs for at least one minute and plugging them all back in? But mainly I kept getting told that I needed a cellular plan.
Photo of Dinh
Dinh, Mobile Master
  • 32,640 Points 20k badge 2x thumb
hi Linda,
Who was sending the email that you needed a cellular plan? it is strange to hear so, Can you post a snapshot of it here (delete all personal information before posting pls).
There shouldn't be any requirement of a cellular plan in order to use wifi.
Photo of srlawren
srlawren
  • 2,184 Points 2k badge 2x thumb
Do other devices on the same WiFi network work fine?  IE can browse to various websites fine using the computer attached to the same WiFi?  If so, then I don't think it's the router as others have said.  You could always try turning the WiFi router and cable/ADSL modem (if seaparate--they may be a single combined device) off for 60 seconds and then back on and wait a few mins and try again to see if that changes anything.
If that does nothing then maybe try a network reset on the S4, and if that still doesn't resolve it, factory reset maybe?
EDIT: actually try this first:  https://thedroidguy.com/2018/04/galaxy-s4-ap-currently-not-in-use-internet-connection-slow-error-oth...
