I dropped my i-phone into water. Nina
  • Updated 3 months ago
I dropped my i-phone into water and touch screen stopped working. Is there any way to revive it? Thanks. Nina
Photo of Nina Krakovna
Nina Krakovna
  • 350 Points 250 badge 2x thumb
Posted 3 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 202,956 Points 100k badge 2x thumb
It may be too late but you can try putting it into a bag of rice for a few days and see if that will dry up the components inside. Turn it off and don't use it anymore until you've put it into a sealed bag of rice for a few days and see if the damage is permanent or not.
Ideally as soon as you drop a device into water that isn't water resistant at all you should turn it off immediately and wipe as much water off and shake out water out of the ports and put it into rice for a few days for the best results. Since you tried using it though it may be too late and you'd have to bring it to Apple to get it repaired.
Photo of Dennis
Dennis, Mobile Master
  • 195,850 Points 100k badge 2x thumb
Goran would recommend silica gel (those packs you find in shoes and other retail goods), couscous or instant rice since they absorb moisture better than normal rice
I should have specified instant rice, it's the only rice I use so I forget about others.
Instant stove top stuffing might work as well
Photo of Mats
Mats
  • 21,210 Points 20k badge 2x thumb
A few options in the link below. Hope you can find a way to get it going again.
https://drfone.wondershare.com/iphone-problems/how-to-fix-a-wet-iphone-that-fell-in-water.html
