I changed my plan yesterday from a seasonal hold to a regular plan and my phone still isn't working.
  • 2
  • Updated 2 years ago
Online it says my plan has been changed, but the changes haven't taken effect. When I try texting someone my message disappears as soon as I press send and they do not receive it. I have tried restarting my phone.
Photo of Clara
Clara
  • frustrated
Posted 2 years ago
  • 2
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
Put your phone into Airplane mode and then take it out, try it again. If not working, call tech support and they can help get it working.
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey Clara! A simple powercycle (turn off/on the phone) should do the trick :) Keep us posted!
Photo of Clara
Clara
Hello, I tried both and neither worked. I can receive and make calls, but cannot receive or send text messages.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Did you try taking sim card out and restart your phone?
Photo of Clara
Clara
Thanks, I tried and still no texting.........
Photo of Ivan
Ivan, Mobile Master
Have you tried using a different messaging app? If you're using the stock phone app, try using Google Hangouts instead. See if that solves your problem.
Photo of Clara
Clara
i need to use the phone texting, I don't have google hangouts
Photo of Mayumi
If you can make a call, dial *611 , option 6 for tech support. Tell them you have tried everything suggested here and still texting not working
They will help you fix it
