I changed my plan from $40 Unlimited call and messaging to $40 500Mb of Shock-Free Data but my mobile data doesn't work still disconnected
  • Updated 1 year ago
Mobile data doesn't work
Photo of Noel Savignano
Noel Savignano
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,682 Points 50k badge 2x thumb
Check data is enabled on your phone. Then restart your phone. If it still doesn't work then pull out your sim card and put it back in. You don't have data block added on in your self-serve do you?
Noel Savignano
Hi Goran, No, I don't think so. But I m going to try your suggestion
Noel Savignano
Nop, Mobile Data says: iDisconnected because service is unavailable
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
Log into self serve again and see if your plan is switched over to a new plan.
Also, check if you have "Data block" on your account as Goran asked.
Photo of Robert
Robert, Mobile Master
  • 106,876 Points 100k badge 2x thumb
If you do, you would need to call Koodo in order to remove it!
Photo of Tim Burgin
Tim Burgin
  • 60 Points
Some phones have to manually put in the server...
Try this:
Go to Settings
Go to Data Settings
In the top right corner, in the drop down menu, select "Mobile Networks"
Select Access Point Names
Add an Access Point
Address: sp.koodo.com
Hope this helps!
*Note, if you can't find the access point names menu then this solution is not for you.
Noel Savignano
Hi Tim & Mayumi,
I've tried to add an Access Point as you've suggested and it works !!
Thanks you guys for your precious help. ;-)
Noel
